I put a 2" snorkle on my bike and a dyna cdi now it needs to be rejetted. I can cover the snorkle in almost half and it seems to run better (that means im lean right?) I have read alot on this but I figure I"ll ask here and see what you guys come up with. What I have done so far is to replace the pilot jets to 40 instead of 38s but I havent put it back together yet and drilled out the air/fuel screw and adj. to 2.5 turn out. What do u think shim the neddle .040? not really sure how to do that a pic or two would help on where to put the #4 washer or washers. keep stock mains ? don't want to get a jet kit if I dont have to. Both of my head pipes are solid white all the way to the muffler.hot wired the fan on a switch and it will over heat within 2 miles with the fan running all the time (bad thermostat?).any help will be greatly appreciated thanks
