1 - 8 of 8 Posts
does anyone know why oil would be coming out of the duck bill under the airbox on a 08efi 750
Wheelies.Some times wheelies,climbing tall steep hills or high RPM runs will cause it to puke oil up the crankcase line into your air box. Once there it will drain out of the Duck bill.
10 4
over oiled the filter? iv done that
the only way to solve it is to run the crank vent up to the pod w/ a filter on the end, OR do the catch can mod. And seal up the holes it left in the airbox, also, if you ride in water, at all, you should scrap that duck billed POS and seal that up too.
where is the duck bill
(sitting on the bike) it's on the upper right side of the box.
thanks i will check it out
1 - 8 of 8 Posts
