it is possible but i couldnt really see it but you can check for sure wouldnt hurt normally you will just lose power not to say it couldnt rub through and cross to another wire not too sure really where or how they ran the circuit havent had any electrical problems yet other than the resetable fuse for the fan the terminal rotted off the fuse so havent done a whole lot on the brute to be too familiar with it but......i will have a look tomorrow and see if i turn anything else up.......i personally would probably try starting from the switches back to start with though.....alot less like trying to find a needle in a haystack
