Like the title says post up the parts that are avaliable from local parts stores to help a few people out to get them back rolling a little faster while keeping several $$$ in there pocket at the same time!
This is for the Gen 1 500/650/800 not the Gen 2. I am not sure if there the same!! maybe someone knows.. Here are a few that I use
front axle seals and front through shaft seal- oem 705500255, replace with 25x47x7
-rear axle seals. oem, 705500751, replace with 30x47x7
-gearbox imput ,(behind secondary clutch) oem, 420950087, replace with 32x47x7
-gearbox rear output ,same as above ^^^^^^^^^^
U-Joint - Advance Auto part number 1-1557 - *weaker then stock
Fuel Pump- AutoZone part number E8213 -
One Way Bearing Grease - Isoflex topas NB 52-
Fan Relay - Advance Auto Brand was BVD Part # R3110Z-
Belt - Autozone / Advance Auto - Dayco XTX2236 suppose to be the same as Highlifter --
Also- Carquest has a Gates G-Force - 30G3750- some people say its not as strong
Fan- Autozone - Torq Flo 10inch - The harness plug will need to be changed.
good thread, making it a sticky
snorkel my ATV has snorkel kits for the 13 renegade 1000's pretty cheep and easy to install. i have one on mine and have taken it pretty deep sense i put them on and works great
