1 - 20 of 20 Posts
i have a 07 750 and ive been worried about water getting in the pull start is this something to be concerned with and if so who makes a shield are how do i?
when it gets it dont worry it goes no where but if you want put some rtv around it and then some on the pull cord and you will be fine
I seen an 06 Model Brute with an 08 pull starter cover in it...atleast that is what the guy said.....Is that really possible or was he shooting me a line of BS??? I haven't even thought about it or even looked into it...LOL!
I have one on my 07. To me it is something to worry about, the pull start fills with mud, wears out the seal and then your exposing your crankcase to mud and water. You can order one for an 08 from your local dealer or online at any of the oem places for cheap.
Cool...I will get me one at work this evening...
whats up with the 08 pull start? does it not leak or something?? anyone got a pic?
they dont have a pull start. they have a cover that goes in the place of it.
yeah we do :)
get that cover. as HeadC1 said water can get in over time thru that seal (for you guys with a pull start)
they don't sell em for nothing!
I found one on bikebandit.com for a 08 750, about 12.00 for the cover and 6.00 for the gasket.
sounds good there.
so the 08 cover will fit over the pulley on the end of the crank without having to remove it
For all the good my pull start does I might as well cut the rope and seal it with silicone.
I thought about that....:thinking::rockn:
No you will have to remove the pulley. Atleast I did on mine, but when I got my bike the guy gave me a metal cover. I ordered the one from bikebandit for my wife's bike and it is plastic, may stick out further. I'll check tonight and let you know for sure.
Discussion Starter #16
did you just remove the bolt and pulley are did you put the bolt back:banghead:
I put the bolt back and I forgot to look last night to make sure the plastic cover from bikebandit fit over the pulley or not.
Discussion Starter #18
Installed the 08 pull start cover with some rtv did not need to remove pulley are bolt seems to seal great and cost under $10
Discussion Starter #20
i had a little bit of sand in mine ive just got to much invested not to do this simple fix i saw my buddies honda motor start smoking because of this so i wouldn't chance it
1 - 20 of 20 Posts
