I did mine like everyone else has done there's just thought I would post some pictures of it for fun...
Here's the little switch I used. It lights up, I didnt wire up that part the other day b/c I was running low on connectors... but I'll go back and wire it up eventually.
I used the cover (little plastic mount) that it came in to mark the hole.
Cut the hole out w/ my pocket knife & cleaned it up a little with a real fine rasp.
Switch pushed in the hole & wired up. I ran a jumper from the blue wire on the fan, to the corresponding pole on the switch. Then ran my hot to the switch from the hot on the accessory plug mounted in the shroud... this way the switch only has power to it when my key is on, and I wont forget to cut it off and run down my battery.
Cover put back on.
Finished product.
Cover put back on.
Finished product.
