1 - 20 of 20 Posts
radiator hose went flat . how do i bleed air out of the radiator hose
or is my water pump shot or my thermostat shot . eny answers
its over heating fi lights came on and temp light
told you that u had air in the system..
You need to run the bike the with cap OFF.Make sure you keep topping off the radiator and run it till hot so that thermostat opens.
i have tried everything ran it with cap off on a hill
now i'm wondering if your thermostats is not opening.
only way to check it to take it out and get a pot of boiling water..
ok man do i need a new gasket if take the thermostats out
likely not.
ok cool man
Lets Get It
Its O-rings on the t-stat housing, no need in worrying about gaskets
If you take it out, replace it and the gasket too. Not expensive enough to worry about it.
And when ya bleed it, make sure shes flat.....it will air lock on a hill.
squeeze the hoses........... ;) Thats how I use to force some air out of the trucks radiator when replacing it... Squeeze the hoses & the air will bubble out sometimes.
Discussion Starter #11
wood a Radiator Pressure Tester get the air out of the system..
fo sho thats jmo thats the best way to get air out of your cooling system
I dont think a pressure tester would get the air out...
Discussion Starter #14
thermostat is good maby its my fan was off
dunno man hose should not suck flat. that usually says air
Discussion Starter #16
ya i donno maby water pump
No.
Just bleed it, over and over and if you still have air, take the stat right out. If you still get air, start thinking the worse....head gasket.
Make sure your rad cap is the highest point and machine is level. Let it warm up (not overheat), re-install the cap and then cool completely (overnight if needed) with the rad cap on, if working properly, it will take fluid from the resevior to fill the system. If it does not, you have a blockage (most likely thermostat stuck) or leak (no vacuum to suck fluid from the resevior).
Discussion Starter #18
not 100% but think its fixed the overflow hose was pinched form the radiator to the overflow bottle it let air out wen i un pinched it
Yep, that's the blockage!!
It's always something simple, that's what makes it hard to find....lol
1 - 20 of 20 Posts
