Is there a writeup anywhere or has anyone ever removed the choke on an 07 Brute 750? I think mine is sticking and want to remove the whole thing.
Banned
They manual has instructions on removal. I wouldn't suggest doing away with the choke completely. Some people say they plugged the choke port with silicon and tried choking it by covering their snork , but, that doesn't work very well. Just take the cable ,choke assem. apart for a good cleaning and lube. There's also replacement spring you can get that's longer ans stiffer than the stock one.
Top: Factory Spring
Bottom: Kawasaki Part# 92081-1720
Thanks Stogi I guess I overlooked it in the manual I will go back and look again and thanks for the PN.
i wouldnt delete it,just fix it.
