1 - 1 of 1 Posts
Hey guys, I'm new to this forum. I know a bit about to ATV's and would like to be helpful if anyone has questions. I used to ride with my uncle and cousins growing up and now work for a pretty cool ATV parts company. I've learned a lot about parts and assembly and would like to be of assistance when I can and also gain knowledge from others.
For a helpful icebreaker here is a thread to a commonly ask question I often get asked:
Question: How to change bands on a boot????
There are no special tools required to install pinch type clamps. The pinch type clamps are sent with all our boot kits and CV joint kits and are specifically sent because no special tools are required. A pair of pliers or tile snips will be the only tools needed to install a pinch type clamp.
Step 1: Hand Tighten
Start by wrapping the band around your boot once its seated on your joint. While this guide shows the inner joint, this guide works with the outer too. Looking at the band, you will notice it has notches and tabs. Hand tighten the band by squeezing the band and locking your tabs into your notches as tight as possible.
Step 2: Pinch the Box Tab
Notice there is a little box tab that protrudes out more than the other tabs. You will want to take your tool and pinch the sides of that little box.
Step 3: After Pinching
Once you have pinched the box tab, it should mushroom up as seen in the picture.
Step 4: Hammer Tab Flat
The last thing you want to do is grab a small tack hammer and just tap down the mushroomed tab till its flat, just in case there are clearance issues.
Using the Economy Banding Tool with band-type clamps
Step 1: Slip tail under buckle and draw tight
Wrap the clamp around the CV boot and thread the tail through the buckle. Draw it tight
Step 2: Bend excess back to hold
Helpful Tip: Bend the excess tail backwards to hold it in.
Step 3: Attach banding tool
Insert the tail of the clamp into the head of the banding tool and slide it through the slot of the winding mandrel.
Step 4: Tighten the banding tool
Tension the clamp with a clockwise motion using a ¾" socket wrench.
Step 5: Bend back clamp
After sufficient tension has been applied (the clamp is tight enough to hold the boot from turning on the joint but not too tight that the boot is damaged), lever the tool back over the buckle to put a bend in the clamp to hold the tension (you may want to tap it with a hammer to put a good crease).
Step 6: Tap down the ears
Complete clamp installation by tapping down the tail of the clamp against the buckle and then tapping down the buckle ears to hold the clamp tail. Cut off excess band with the tin cutter.
Using the Professional Banding Tool
Step 1
Wrap the clamp around the CV boot and thread the tail through the buckle. Draw it tight.
Step 2
Step 3
Depress the locking pawl and tension the clamp with a clockwise motion of the ratchet.
Step 4
Step 5
Cut off excess band with the cutter and remove the tool.
Step 6
Complete clamp installation by tapping down the tail of the clamp against the buckle and then tapping down the buckle ears to hold the clamp tail. Remove excess band from the tool by lifting the locking pawl and removing the ratchet.
Hope this was helpful to someone, will try and post at least one helpful tip a week!
- SabrinaATVPC
1 - 1 of 1 Posts
