O'riellys 10" electric fan made by Proform. Part # 67010
Cost $53.40 + tax :wiggle:
Kawi replacement fan $296.26 + shipping :nutkick:
This fan is a perfect fit and is actually about 2" wider in diameter than the stock and has ten blades compared to 4 blades on the stock fan. If I was to give an educated guestmation it pulls 2.5 times as much air as the stock fan.
Yep... The black is ground and the blue positive. I used spade connectors on mine so It can be unplugged when needed. Matter of fact I had to do away with the stock plug on the fan circuit a while back because it went bad . I was having all kinds of problem with the stock wiring on the fan circuit so I rewired the whole thing from the battery to the fan back to the ground.
this sounds like a worthy and cheap UPGRADE. More air/larger diameter = more and quicker cooling.
Heck I'm going to do this when I relocate my radiator for sure.
Another question... how does the new fan mount to the radiator?
It utilizes a nylon zip tie type mount that sticks through the fins on the rad. The mounting hardware that contacts the rad has a wide footprint so it won't damage the rad. The fan is super light ,lighter than stock, so your radiator won't be supporting much weight at all.
I'm ready for this one. With the heating problems the brute "seems" to have more airflow gonna help a lot. Though when my stock fan cut on it only did so for 20 seconds or so. I bet that new one runs even less.
The frame of the new fan sets flush against the rad pulling more air through the rad . The stock fan sets away from the rad. This causes the fan to pull air around the sides of the fan when the rad starts to get restricted.
Some one should do the temp gauge mod before this one.And get some temp readings then add the new fan and see if it helps. Or i guess you could test it with out a temp gauge by letting it idle till the fan comes on and time how long it takes to cool it down enough for the fan to go off.then repeat the process with the new fan added.
The fact its so cheap compared to stock is great if your needing a replacement but it would be really cool if it had a cooling advantage to it as well.
I actually found a universal 10'' fan on e-bay for like 25.00!!! hey it works much better not sure on temp readings but the fan used to run constantly after about a hour of slow riding now it only runs about 2 mins and cuts back off for a while so i assume it cools better stock fan was 8'' with four blades new one is 10'' with 10 blades
If it were me, I'd go the cheaper route first and buy the 10 blade fan and put a switch on it. If it still doesnt help then get the HL radiator and got the the upgraded fan w/switch.
Related Threads
Mud in My Blood Forum
305.8K posts
24.5K members
Since 2008
