*Originally posted by phreebsd*
This is a quick, simple and cheap mod because it costs nothing!
If you look down by the radiator overflow tank you will see 2 connectors attached to the motor casing. the Top one is the Neutral sensor and bottom is the reverse sensor.
Just pull off the reverse sensor (pulls straight off) and tape it up.
Now you have no reverse limiter.
Be careful. You now have full power in reverse.
**Disclaimer** - The staff of MudInMyBlood.com can not be held liable for any damages to yourself or anyone else after performing this partcular modification.
