1 - 15 of 15 Posts
Ok here we go,my 08 brute is lower in the front than the rear. I have checked the lift, put 07 springs on and still no luck. It is very noticable and aggravating.What else can I check? It is worse than the pic shows.
try puttn some 05 springs on i hve no prob with mine and it looks like u have a big ### tire up front and a smaller one out back and u could try the gorilla spring spacers to try and get the sag out its wat i use
All tires are the same. 29.5-10-12
Could it be the shocks worn out? Just guessing here:thinking:
Also whats the deference in height between the front and back?
About an inch in difference. It did it with my 08 springs.Figured they may be worn out so I bought some 07 springs. Same problem.
SAY I WON'T!!!
I've got some 05 springs I'm gonna get powdercoated and put on to try and fix the same problem. I'll have to get back with you on that later...
what spring settings you using?
turned up all the way around?
i have HL springs and my front has less ground clearance than the rear.
mot much difference but still..
SAY I WON'T!!!
I always keep mine turned all the way up...not worried about putting the Gorillas in a bind after the new lift.
All four turned to max. Mine you can tell a big diff. Dont know what else to try. Maybe change them around just for kicks and grins.
I thought you were talking about your ole lady there for a second.... :D
HL springs are probably the quickest, easiest, etc...
Im going to sell my Highlifter springs off of my bike and that may help you out.Shoot me a Pm if your interested.
you still selling the orange beast?
You can also put the rear springs up front the rears seem to be stronger
Discussion Starter #15
This is a better pic of what im talking about.
1 - 15 of 15 Posts
