***Admin Edit*** The information in this thread mostly pertains to 2005-2011 kawi clutches.... 2012+ saw design changes and it's best to just call VJF (Vforce John). He's the best when it comes to kawi clutches.
From EPI:
Maroon (Lighter than stock. Not the same as the maroon primary)
Black (Almost same as stock)
Almond (Good for 27'' and lighter 28'')
Green (Good for heavier 27'' and all 28" )
Lime green(Good for heavier 28'' and maybe 29.5")
Red (Perfect for 29.5'' and the lighter 30")
Yellow (Good on only 30'' or larger most aggressive tires)
From VFJ:
#1 Gray/white
#2 Orange/Purple
#3 Orange/silver
#4 Gray/Red
And while your changing springs, if you need to add/change shims for belt slack, these are the available shims:
Spacers
Part No. -------------Thickness
92026-0034 --------- 0.3 mm (0.012 in.)
92026-1569 --------- 0.6 mm (0.024 in.)
92026-1617 --------- 0.8 mm (0.032 in.)
92026-1565 --------- 1.0 mm (0.039 in.)
92026-1570 --------- 1.4 mm (0.055 in.)
From EPI:
From VFJ:
#1 Gray/white
#2 Orange/Purple
#3 Orange/silver
#4 Gray/Red
Spacers
