1 - 8 of 8 Posts
I made a spring compressor tool today so I could install new HL springs. I used a 2x2x3/16 angle, 1x1 square tube, and two 1x1/8 flat iron. All purchased from the home depot for around $25. The tool worked great on the front springs. But the back springs on my 09 brute are signficantly stronger than the front. I bent the two 1/8 flat irons I was using as the handle. I'm gonna pick up two 3/16 flat iron tomorrow and remake the handle. Hopefully that will do the trick. I'll take pictures tomorrow.
good deal. that oughta help some folks make their own.
Here are the pics. The first one shows the bent handle. The other pics show v2 of the tool with 3/16 steel handle. That worked fine. I recommend that you just spend the money and buy the tool from HL or your favorite vendor. The front springs come off without a lot of muscle, but the rear springs really took some pressure. Your vice has to be tightly mounted to a base that doesn't move. You really have to use the leverage of the 36" handle to compress the rear springs, and you really need a 2nd person to pull/insert the spring retainer because your hands are full. This is a dangerous task and you could really hurt yourself or a helper if something goes wrong.
Now that i"m done with it, it is for sale. :)
btw, the HL springs really had an impact on the brute. Here are the before/after measurements of the brute with an extreme 2" lift.
Front fender: Lift-34-3/4". Lift+HL Springs-36.5"
Footwell: Lift-13.5". Lift+HL springs-15.5"
Rear fender: Lift-31". Lift+HL springs-33".
Also, while i was in metal fabrication mode I made up a secondary clutch spring compressor in anticipation of delivery of a set of Red and Almond springs.
  • Like
Reactions: phreebsd
yeah those rear springs are tight. i was trying to put some spacers in mine and ripped the vise right off the bench. lol. and i didnt even use them.
I went a made a spring compressor yesterday as well. It consited of two 1 1/4 pipe floor flanges and two 1/4 inch all-thread and some nuts. I started by pulling out the grinder and cutting till it resembled a C, and put it in the spring then put the other on the top of the spring. I used two 1/4 all-threads to connect the two and used the nuts to compress the shock.
A tip I learned while doing it is to mount the shock vertically in a vise and use two nuts jamed together to basically turn the all-thread into a really long bolt I then used my impact wrench to turn the whole all-thread. I think parts total was about 20 bucks.
great thread!
on ur clutch spring what did u use to make the bowl part of it?
1 - 8 of 8 Posts
