Hi, I am going to Put Epoxy down on the floor of my shop when it is done, Any tip's? Which brands are good and which to stay away from. Any Links? How does it affect Radiant heating in the floor? The Shop is being built now so the floor is new. Also Drylok should I use it on the concrete walls? What brand? ThanksAcid wash floor till it opens up. U can tell if it opened up by putting water on it and if it drys up quick u r good. Most products will work fine if u prep floor right(acid wash or grind if it has been painted or sealed). The best floor in my opinion is a quartz. 1st coat epoxy then broadcast quartz while its wet. Then put a urethane clear on top. Expensive but badass. You can always just two coat with epoxy but it will be slick when wet.
epoxy floor coating cincinnati
