Hey everybody im new to the site and its probably been ask before but i cant find anything.
I want to put a snorkel from m.i.m.b. on a 2007 brute force 750 with dynatek and full muzzy and want to know the proper jetting specs to use. Right now its running good with no jet kit. I want to know will i have to rejet if I put a snorkel. If its to complicated i wont put the snorkel so any help would be apreciated.
if you use the 3" rubber 90 elbow coming off the air box it will likely be ok.
as far as where to begin on jetting, i think a dynojet kit comes with instructions and give you a pretty good idea on where to start.
There r alot of things that come into play. I just did the same thing to my 07 full hmf moose. I snorked it and then had to rejet. What worked for other people did not work for me most people I talked to was running 138/142 dj 38 pilots and 2 turns. I live in michigan and had to run 142/144 40 pilots and 2 1/2 turns. The other set up was way to lean my plugs were white. So just play with it. I recomend u get a air screw tool. I did not have one but wish I did that way u dont have to pull the carbs to ajust the air screw. I have one on order now
Every bike is different. All I can say is try it.....Jetting can be a pain. Its easy for some and hard for others. Buy a Dynojet kit and start with what the directions say....its a good starting point. I am running a 146 front and 148 rear and 2.5 turns out. I have a HMF swamp series on mine and I live about 1500-2000 feet about sea level. Mine has ran good to every race I have taken it too even down south. If you need any help shoot me a PM. I can help you all I can.
