1 - 6 of 6 Posts
So i'm snorkelin the brute tonight and i had a question or two. I was reading up and sone folks said that if you have a stock exhaust that you don't have to rejet after installing snorks. Well i have a HMF utility and want my bike to run as good as possible so i don't mess it up in anyway. so what all do i need to do to fix this problem...OR will it be a big enough issue that i will have to be concerned with it. Thanks in advance for the advice guys.
it may possibly run lean because of your exhaust. your fuel injected bike has no carb to rejet. a PCIII or similar may be needed to richen it up a bit.
yeah your bike is efi and requires no jetting and for your snork and pipe, i did the same thing snorkels and a hmf and it ran great, some may run a little rough but first just try it and see, most likely you will be ok if not then just add a pc3 all it can do is add power and makes it so much smoother anyways
my uncle had snorks and HMF on his 08 and it runs good, maybe even a lil rich.
I got snorks and Swamp series. no PCIII yet. Ran great all day last sunday even with exhaust leak!
Discussion Starter · #6 ·
AWSOME thats what i wanted to hear guys lookin forward to snorkelin it now was a little worried at first but that makes it alot better.
1 - 6 of 6 Posts
