1 - 5 of 5 Posts
do i need to do this step on a brute force 750i fuel injected
i cood not find the 2 hoses
Remove protective box on front of air box and set aside, you will not need this.
There will be 2 hoses, run into a white canister, with a single hose on the other end,
these are your carb vents. Remove white canister, and attach the 2 vents using a
"T" and run the 3rd line up into the Pod thanks
No sir. that is for carb models only.
Those two tubes that run to that canister are the carb vents.
We have none on our 08's :)
the only vents you need worry yourself with are the radiator overflow bottle and the gas tank vent.
ok thinks
cool ware thos vents
radiator overflow bottle is down by your left foot. there's a tube coming out of it. that's the vent. run it up.
the gas tank vent is on right side of bike. Look under back fender. and u will see it coming out of the gas tank and running into the frame.
1 - 5 of 5 Posts
