Hi guys,
First post here and in need of some help! I've got a 2008 Brute 650i that I recently added an HMF slip on, Uni air filter, and MIMB style snorks on.
Today I adjusted the valves starting with the rear cylinder. I took both inspection plates off the cylinder and rotated the crank counter clock wise until the exhaust valves opened and closed, followed by the intake valves opened and closed, and another 1/4 turn of the ratchet to back sure the valves were on the base circle of the cam.
I then lashed the exhaust valves to .009" and the intake valves to .005". The exhaust were tight, the intakes were probably okay but i re-lashed them to spec anyway. I adjusted them until the feeler gauge slid between the adjustment screw and valve with some resistance. I tightened the adjustment nuts and checked to make sure they were still okay.
I repeated this procedure for the front cylinder (including making sure it was on the base circle). Before adjusting the exhaust was tight and the intake was probably okay again. I re-lashed everything to spec anyway.
Buttoned it back together and it starts great and has great throttle response, however I've still got a tick that seems slightly louder than before adjustment. This is my first time adjusting valves so I'm not sure if this is normal or not? I expected the valves to be quieter.
Here is a video: Brute Force Tick After Valve Adjustment - YouTube
Any thoughts or help would be greatly appreciated.
