I just bought a 2012 Brute 750i w/ EPS and Im new to the forum! Went thru a hole that ended up getting pretty deep, the front end stayed up but the exhaust went under and it died! Towed back to camp flipped it on end and let the water run out, inside of the air box was dry, oil still clear. Once I was back home I pulled the spark plug from the front left and tuned it over a couple times, replaced plug and still wouldnt start. Installed 2 new plugs and put about 3cc of oil in the hole before re installing. Acts like it wants to start and even puffed a little smoke once. I have tried using starter fluid also. Suggestions anyone?
