1 - 7 of 7 Posts
called dealer yesterday and they recommended running Motul 300V 5w40 in the brute. anyone running this or have another oil that is good.
lucas 10w40. royal purple is good too. service and owners manual suggests 10w40. I dont know why they'd say to use 5w.
they may have said 10 I might have wrote it down wrong.
Amsoil amsoil and amsoil
5w40 is a European oil mostly used in high end German cars and most new diesels and yes, it's synthetic.
I'd go with 10w40 and at a minimum make sure it's a oil designed for ATV's.
No offense to the Amsoil, synthetic and all that other expensive stuff, but conventional oil works fine and has for 100 years. The most important thing, regardless of what you use, is to keep oil clean and filter replaced with a quality product, and you'll be fine.
If all those others were that much better, don't you think everything motroized that uses oil would run it?
i use mobil one on mine and its runs great
outside tempurate is -10 to +5 Celcius here now in the winter
1 - 7 of 7 Posts
