1 - 5 of 5 Posts
Just wondering if stock temp sensor works with gauge,if not then what gauge to purchase.
it should work w/ any gauge.
where is the temp sensor on the 08 brutes though i might consider this rather then cutting hose and redoing it all
Is the stock sensor just for the warning light or will it also send the temp to a gauge.
EFI needs an accurate temp signal does it not?
It does more than the light, it also closes the circuit to the fan, making it come on. Which is basically its main job.
1 - 5 of 5 Posts
