1 - 6 of 6 Posts
I have Prairie 650 2003 & i have coolant coming out of where the exhaust comes out of cylinder head a lot. When i took spark plugs out, there was coolant on them need to know what to do
Your heads and cylinders are warped. Yes it is easier to pull the engine to fix this than trying to do it inframe. I can have the engine out on the bench in 2 hrs. Just take your time. You may need to have someone refinish the heads and cylinders. Check very close with a good straight edge. Might only be heads warped. If so get a piece of glass about 1/4" thick. Yes glass. Nothing else will be smooth and level enough. Use some wet sand paper and keep it wet. Sand head in figure 8 and as you do you will see the high and low spots. Continue until its all shiny smooth. Wash good and resemble with new kawi gaskets. It will take a few hours but is worth it in the end!!
1 - 6 of 6 Posts
