1 - 2 of 2 Posts
i have the standard 2 inch mimb style snorkels on the bf, and now with the bbk i need all the airflow i can get, here are my ideas/options,1 leave the snorks as is and run a inch and a half flex pipe snorkel to the pod with the mimb's, 2 run a true 3 inch intake snorkel, or go all flex pipes to the pod aka. ninja snorkel style.
what would you guys think would give the best flow on the intake, to give a little info on the motor, its an aggressive cam and high comp bbk
Lets Get It
Out of your options I would do the 3 inch but i think it would be good to do two 2" intake to the center then the belt exhaust to the pod, someone did it and I thought it was a good ideal, but if you are to do that it would be easier to just run the flex pipe to the pod. So, I dont know now:thinking:!!!
1 - 2 of 2 Posts
