61 - 80 of 167 Posts
Those are the 28x10x12 Laws...they are short as well. the only 28 Outlaws that are any good IMO is the 28x9.5x12 they have a flat profile.
Hey I Was Wondering What A 28" inch zilla with about 5 psi would measure out at? anybody ever put a tape measure up to one?
has anyone checked out the terminator tires that tc atv has on ther website they look huge. bt then agin they are 32s and they look real mean
28" backs on my 750. 29.5" laws on 650 gaylander
and 29.5 laws on 800 Canned ham
Discussion Starter #66
Another example of 30" SIlverback next to a 29.5" Outlaw
i gt a big surprise over memorial day weekend on a big ride when i pulled up beside a guy on a brute wit 32in backs and my 31in laws wer taller and the guy wit the backs even addmitted that the 31s r taller cause he use to have a set. OH YEA OUTLAWS FTW!!!!!!!!!!!!!
I know that my 29.5 'law are as tall as some people's 30 'backs but alot of it depends on how much air you have in them
then you need to read this:
http://www.mudinmyblood.net/forum/showthread.php?t=5515
and also keep in mind that some tires have a more round profile (mudlites) while others have a flatter profile (backs) so, putting them side x side unmounted is not an accuarate comparison.
well the backs run very true to size the 31s are on the same wheels the 32s are on offset wise and the wider tire is pushed to gether making it taler like when you crush a tire so that would make the 31x11s closer to 32s also here are some pics of 29.5x10 laws and 30x14 silverbacks and every 29.5 law i mesured mesured 29.75 so that is why they look so close to the same i think both these have 5 psi or so
If you measure a every atv the correct way...most will measure true to size...maybe some a slight bigger or smaller. I posted a while back on here how companies measure them. Taking a measure tape on the ground while they are mounted or um mounted will not get a true size like most think. For instance I have taken my 28x10x12 Silverbacks and put them beside my older 28x9.5x12 Outlaws I had for a short while and the Silverbacks will be bigger. The post above that Polaris425 posted a link to my thread...I hope it helps some.
so what is the pest psi to run in 29.5x10x12 laws
I run 5 psi in my 10's and 7 psi in my 12's
Measuring the circumference and dividing by pi is the same as measuring the diameter. The issue is that people often have weight on the tire causing it to distort before measuring it. They also measure at different pressures which makes a difference, especially on some tires.
28" Swamplites vs Stock
Lift before and after at rear diff
and at the side before and after
Discussion Starter #79
them swamplites got some good tread on them. im convinced they would be superior in a forest.
Backwoodz Boggerz
a question for bootlegger, how do you get 7psi into an unmounted tire, if you used a tube it looks to me it would spread the bead out farther than if it was on the rim
