Status
Not open for further replies.
1 - 6 of 6 Posts
Im looking at getting new tires and rims for my 2006 Brute 750i. Im in the mud more than anything so ground clearance is big to me. I want to know what would be the biggest tire I can run with stock axles without having to worry. I am looking hard at the 30x10x14 ITP Mudlite XXL on SS112 rims. Should I have to worry about popping axles with these and a 2in bracket lift? Thanks in advance.
There is chance you might break them on the back but it just depends how you drive it
How much of a "chance" am i running? Im not interested in having to replace axles regularly, much less at all.
The mud lites will be easier on axles that outlwas would be. I ran 31's with stock axles for a while. Like mentioned above, it all depends on throttle control. If you hammer on it often, stuff will eventually break. My son n law has 30" backs on his 09 and he's still on stock axles. He's also on a 2" lift and HL springs. You should be fine on the mud lites with only the bracket lift.
---don't go away mad, just go away---
Search... lots of info on this already here.
1 - 6 of 6 Posts
Status
