1 - 6 of 6 Posts
Ok got the radiator on the Brute and made my brackets and everything to mount it in the stock location. Everything is done but one thing. I did not put the factory ? Thermostat ? in it.. Long story short its over heating and not circulating the fluid....Help
Here is a pic of the part I did not hook up, not really sure what it is but I no the radiator has no spot for it....
http://i732.photobucket.com/albums/ww328/usmctadpole/Treys009.jpg
could I just take the 2 wires going to this and hook them togather???
looks like the temp sensor.might need that.not sure.
ok well I hooked the wires up and now my fluid is going threw the whole system.....but it wont stop the fluid in the radiator to cool it down more, I am leaving to go rideing at 4 so if I cant fix it between now and then....then we will see how she does like that
r u certain you have worked all air out of the system?
100%
that radiator has three cores compared to the single stocker,it should be good.let us know
1 - 6 of 6 Posts
