This install is very easy. I rate it a 1 on a scale 1/10.
Tools required
One large phillips head screw driver---for the battery
One small phillips head screw driver---for the vdi install
Your choice or pop rivets or zipties to hold it in place
First step disconnect the negative on the battery
Next step is to locate the Stock ECU and unplug the 2 wiring harnesses holding it in place(indciated in the picture). Just push down with your fingers and it should loose up, if not use some wd-40.
Next step is to install the Vdi wiring harness to the Vdi ignition module, first you will need to remove 2 small phillips head screws before connecting the harness, make sure to use die elecric greese here. Just align the harness and snug the screws.
Next step is to install the Vdi harness to the plugs. Use die electric greese here as well. You will here them snap into place.
The next step is to install the Vdi control unit, I placed mind in the center and used zip ties to secure it for now. I will be using pop rivots later on. I also put some foam weather stripping under the Vdi unit to keep it from vibrated or rubbing against the frame. Install the seat, the seat will fit, it might not look like it will but it does. Just push down hard.
The last step is to hook the negative battery cable back up and fire it up. I usually cut mind off before switching maps with the toggle switch. Enjoy!!!!! You should def tell a difference. Sorry for the crappy pics all I have is a camera phone.
Tools required
