1 - 5 of 5 Posts
hello i just bought a 2008 750 brute. n im gettin ready to snorkle it. is there any vent lines i should run to the pod or up the snorkles? thanks
gas tank vent, and radiator overflow vent, and optional crank case vent. i say optional because it's not 100% necessary unless you begin having problems with oil in your airbox.
check here for how to do your gas tank vent.
http://www.mudinmyblood.net/forum/showthread.php?t=11
make sure you fill the hole in the frame with silicone or something
your radiator overflow is right beside your left foot. there's a tube comin out of it, ran part of the way up. mine was under the seat somewhere. just follow it up and extend it up into the pod
k thanks...
Discussion Starter · #5 ·
thanks for the welcome..
1 - 5 of 5 Posts
