it compresses together. use some muscle or find a pry point to force it to compress together. its likely filled with sand/dirt/grit/mud and even some rust. try tapping it a few times before trying to compress it.
Phree,
Took my bike in and had them do the front and rear oil seals under warranty. Now my front diff seal is leaking. Is this common for it to leak after they re install the propeller shaft?
gonna end up by doing this seal myself cause I snorkeled the bike right after I got it back from warranty work and voided the warranty. Just wondering if my front engine seal will start to leak if I pull the shaft again to do the front diff seal.
i just did this for the first time today,and all i can say is that booger is a beast to get out....that was the only problem for me..after lookin at this video
little tip on taking the oil seal out. take a tire plug tool, cut the barb that would normaly hold a plug. and cut it off. to were you wve a little hook on the end. use a bench grinder. flatten it like a flat head screwdriver, and sharpen it, to were it will cut through the seal. now it will take about 2 sec to pull it out, without removing your floor boards
This may be a stupid question. The part numbers that you gave for the seals. Is this for the number for the seal you changed in the video and the rear seal of the front differential? So both seals for the drive shaft?
I'm going to be changing the front pinion type seal this weekend. After you pull the driveshaft out do you need to undo a pinion bolt to remove the coupler? Or can you remove and install the seals around it? Also what is the torque for that nut if it does indeed need to be removed? On a 2005 650 SRA.
Thanks in advance!
---------- Post added at 01:18 AM ---------- Previous post was at 01:18 AM ----------
Thanks in advance!
21 - 40 of 57 Posts
