Front Brake Master Cylinder on a 05 Brute Force 750 took a dump, anyone rebuild?
4.7K views 1 reply 2 participants last post by  rmax
#1 ·
Front Brake Master Cylinder on a 05 Brute Force 750 took a dump. What happened was the front brake was locking up and causing drag, so I drained, flushed, and bleed the brakes. It would not build pressure after the bleeding no matter what, and then I noticed some black crap coming through the hole (where the fluid goes into the actual master cylinder) so I'm guessing the black o-ring descided to crap out.
Anyways... Has anyone rebuilt theirs? Is it a pain / easy? Any tips?
Thanks!
#2 ·
not a hard job just look in manual it will walk you throught the rebuild
